one_hot and zero_one_hot
wangkl
Member level 3
Member level 3
FSL
zero_one_hot
What's the difference between these two concepts: one_hot and zero_one_hot?
I'm a little bit confused.
what does one_hot pragma do
Hint:
Use google to find zero_one_hot and read the first record.
zero one dirty.com
It's a pdf file and without any explaination.
I guess google is characterized for different location.
Actually, I met problem while I read Cadence LEC document:
ADD PIN CONSTRAINTS
ONE_Hot Specifies that only one of the pins can have a high value.
ONE_Cold Specifies that only one of the pins can have a low value.
ZERO_ONE_Hot All pins can have a low value, but only one can have a high value.
ZERO_ONE_Cold All pins can have a high value, but only one can have a low value.
example of one hot constraints in cadence lec
OK.
I will post what's in the pdf:
The definition of one-hot as given here ("in which only one
signal in the collection is active at a given time") is useful one,
but is not the normal definition of one-hot. (In OVL, the Open
Verification Library, this check is known as zero_one_hot.)
This will cause confusion.
Change the definition of ONE_HOT to "...in
which one and only one signal in the collection
", and add a second
attribute ZERO_ONE_HOT with the definition
"...in which at most one signal in the collection
". Similarly for
ONE_COLD and ONES_ONE_COLD.
Will u be satisfied now ? :)
    wangkl
zero one dirty
So in the other word:
One_hot: at least 1, only 1 and at most 1 "one" is active in a given time.
zero_one_hot: at least 0, and at most 1 "one" is active in a given time.
Is my understanding correct? Thanks!
can u explain for one cold with one simple example
one hot:
only following states is available
state[2:0] = 3'b001;
state[2:0] = 3'b010;
state[2:0] = 3'b100;
zero one hot:
state[2:0] = 3'b000;
one cold:
state[2:0] = ~3'b001;
state[2:0] = ~3'b010;
state[2:0] = ~3'b100;
zero one cold:
state[2:0] = ~3'b000;
thanks
but how synthesis tool will understand this condition
whether we have to set any pragma for this conditions?
thanks.i usually use one-hot.could you give me the difference when we synthesis one-hot and zero-one-hot?
