How can you simulate the wire bonding with CST?
coniglioe
hi
how can simulate the wire bonding with CST?
It's possible assign a material at bonding?
Tanks
Re: cst wire bond
Hello Coni,
In objects/basic shapes/Bond Wires. It will open the bond wire window. Then youll see that at the bottom, in "material", you may assign any material you wish, instead of the default PEC.
hope it has helped you.
mpero
