HP_compaq laptop service manual
NTFS
Member level 3
Member level 3
nx5000 service manual
hi
My laptop LCD became dim sometime. and I do not know why.
I can separate all of my laptop components except its LCD.
now I want a service manual for it ( or your experience to help me).
my laptop model is nx5000, but any HP_compaq laptop service manulas can be helpful.
Thanks.
presario v1000 laptop service manual
Hello!
If the display is getting dark probably the CCFLs are worn. Insert new ones, that should do the job. When buying spare parts measure diameter and length and be sure to get ones that will fit. They are pretty cheap (about 10 Euro each) so this should be a cheap repair.
CU
compaq nx5000 service manual
Dear NTFS,
I have uploaded the Service Manual for your HP Compaq nx5000 Notebook PC. This will enable you to identify the faulty part and a detailed explanation on how to remove and install the new parts for your notebook.
Best Regards,
Bernard
Reactions: grage2010
    NTFS
    grage2010
hp nx 5000 service manual
is ccfl light or inverter or signal line?
nx5000 ram how-to replace
Another issue with regards to the LCD is when
“Laptop shuts down on power up. When the power button is pushed, the laptop flashes green lights for several seconds and then powers down. Unit will not stay on with battery or when plugged in”.
Trouble shooting:
I plugged the AC adapter and tried to turn on the laptop. After I pushed on the power button, fans started spinning and were active for a few seconds and laptop just turned itself off. The video never came on. I tried to power it on for a few times with the same result.
Here is how I fixed it.
First of all I tried simple stuff: remove the battery and start the laptop with AC adapter plugged in, reseat and swap the memory module, remove the hard drive, the DVD drive, the wireless card. Nothing helped to start the laptop normally. After that I went a little bit further. I opened up the laptop case, removed the LCD screen assembly and reseated the video card and… Surprise, surprise, the laptop started fine with an external monitor attached. Just in case I restarted it 3-4 times and each time I got video on the screen. After I assembled everything back, one more surprise was waiting for me. The laptop failed to boot again with the same symptoms. So, the only part that I added before it failed was the LCD screen assembly. I unplugged the video cable from the system board and the laptop started fine again with the external monitor. Now I know that the problem is somewhere inside the display assembly (of course, if the video connector on the system board is fine). The next logical step would be opening up the LCD display assembly and check if all connectors are seated properly. Bingo!!! I wasn’t very surprised, but I was very happy. The video cable was half-way out from the connector on the back of the LCD screen. The laptop started perfectly fine as soon as I plugged the video cable back in place. Fixed!
That was my first experience when improperly plugged video cable prevented entire system from booting.
service manual for hp laptops (new models)
just trying to find out how to open a hp compaq nx5000 to install new ram but i cannot download the service manual because of no points
how to remove screen from hp nx5000
Dear users,
Please supply relevant hardware details i.e. Make, Model, Product code, even the Serial Number, this will assist us greatly in helping you fast and efficiently.
This HP Compaq nx5000 Notebook PC comes in several different models, although they look the same the hardware differ in many ways
Here you can see all the different models alone:
_http://h20141.www2.hp.com/hpparts/Search_Multi_Product.asp?mscssid=QQT4RWBJ5B529HAURM25V2RSADUAAG7B&SearchCriteria=NX5000
Service and maintenance information
1. HP Compaq nx5000 Notebook PC - Maintenance and Service Guide
_http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=395654&targetPage=http%3A%2F%2Fh20000.www2.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00713410%2Fc00713410.pdf
Troubleshooting information
2. HP Compaq Business Notebook nx5000 Series, Presario V1000 Notebook PC -Maintenance and Service Guide
_http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=395654&targetPage=http%3A%2F%2Fh20000.www2.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00713403%2Fc00713403.pdf
3. HP Notebook PCs - About LCD Panel Defects and Terminology
_http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=za&taskId=120&prodSeriesId=395654&prodTypeId=321957&prodSeriesId=395654&objectID=c00035844
4. HP Notebook PCs - Display is Dim During or After Startup
_http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00832191&dlc=en&lc=en&cc=za
Kind Regards,
Bernard
www.bcx.co.za
Added after 1 hours 2 minutes:
Service Manual for HP Compaq nx5000 Notebook PC
_http://h10032.www1.hp.com/ctg/Manual/c00158356.pdf
Cheers,
Bern
