Tie or float spare cells?
jelydonut
Full Member level 4
Full Member level 4
When adding extra std cells to a layout, do i need to tie the inputs high or low, or can i let them float?
jelydonut
It wont hurt to tie them high to avoid some noise.
Also, if you have spare registers you may connect them to the clock which should create a clock tree, so if you use the register it will have the right insertion delay
    jelydonut
You need tie the input to 0/1 to avoid the warning and if you use the FF, you must connect the FF ck/rst pin with the correctly clock and reset tree.
Thanks.
Lsong
You can not leave an input pin floating. You have to tie it to hi or low or a known
signal such as clock. Otherwise short circuit current through PMOS & NMOS could happen and waste power consumption.
