What is the best method to save power in a battery powered project?
mana111
hi
i'm doning my first battery powerd project and i want to know what is the best methods to save power like which is better the internal pullup or the external pullup?? and if it's the external which is best pullup or pulldown??? and any other ideas please.
thanx
Re: power managment??
hi, In first place you could start thinking in a MicroController designed for low power consumption. Then, you should study different ways of software strategies for switching between active and power off mode.
Also, all the Ics LowPower Oriented will help (for exaple, for linear regulators, texas has many little regulator with very little IQ in Active or Off mode).
    mana111
As for the pull-up or pull-down resistors, I don't know what you mean by internal or external... Most of the time this is determined by the ICs you need to use. If there are internal resistors where you need it, then no need to add external ones. If not, then you must use external resistors.
There's no best choice between pull-up or pull-down, it all depends on what the resistor is used for. When it happens that you can use either one, then choose the type that will be inactive most of the time. Use large resistor values, but be carefull to chose a value that bias the input where it is tied properly.
Best of luck,
cyberblak
    mana111
power managment??
thanx alot
