Need analytical expression for fractal antennas
arunkumar
Junior Member level 2
I need a fine analytical expression for designing fractal antennas(sierpinski gasket/carpet). Do anyone have these design equations??
there is no equations. only fractal dimension
As fas as i know about fractal is more sort of a definition. Any design satisfying the definition is a fractal design.i.e
A self-similar structure whose geometrical and topographical features are recapitulated in miniature on finer and finer scales.
I hope that following paper and thesis on the topic might help.
use that link amster thesis of fractral antenna
hi ArunKumar
I try to design the Fractal antenna using Sierpinski carpet and start first iteration by finding the length and width of antenna.
but it's a square so i take L * L so L as width of antenna but it will not resonate at that frequency so i m confused.
can you help me to find out the exact dimention for the exact frequency radiation and exact feed location for the same antenna?
