how to fix duplicate part name
neena
Member level 4
Member level 4
pluto
hi all
i am facing a problem in concept HDL
when i export the schematic to layout
an error is accurig
The error message is duplicate part name found on line 2
how ro fix this problem
regards
neena said:
hi all
an error is accurig
regards
I think you have to go to that line, and revise it, you may wrote something twice,and it should be written once,
or attach your code, someone may debug it
Regards,
ahmad,
hi,
normally this error occurs due to duplicate part referances
that is if there is referance U1 and agin it is present for some other part
than this error occurs u have to check the schematic for part referances.
    neena
