How much will two NMOSFET with the same dimension differ?
foreverloves
question on mismatch
if I design two NMOSFET with the same dimension (W/L), how much will they differ from each other when they are fabricated?can one be a "slow" type and the other be "fast" type?
because I need the two transisors to match well
thank you!!
try some matching techniques in layout, common centroid or interdigitating.
Re: question on mismatch
They'll be different, in many respect:
physically mainly due to non-uniform ion implant concentrations,
and electrically Vth, Leff, Idsat,...shall be slightly different.
(~1%)
Say we are looking at mismatch of Gm, that shall also be function
of W, L, Vgs-Vth,... and layout style of cource.
Try to obtain "Matching report" from fab.
thank you!!
thank you again
Unlikely, by variation we include
(1) lot to lot variation
(2) long distance (>1000um) variation within wafer
(3) short distance (~10um) variation within wafer
Corner case usaually happen to (1)
where gate oxide, channel implantation vary to certain degree
which is highly unlikely to happen in (3).
For example, poly resistance can have corner value +/-30%
but matched pair can be within ~1%(1 sigma) with careful layout.
thank you!!
basically, u need larger L and common centoid layout to reduce the mismatch.
thank you!!
very very unlikely you will get one slow, one fast.
those corners are to take care of absolute vairations from lot to lot, run to run.
You can read the book of Razzavi p.465.
Their VT will different by : Tox / sq(W.L) with Tox in nm (Cf your model card)
W and L will also vary a little, but less than Vt.
OkGuy
thank you!!
Transistor may have distinctly different performance from die to die.
But close-spaced transistor on the same die will have almost the same characteristics, i.e. "fast" and "slow" will not happen on these transistors.
foundry mismatch characterization report gives you how much Vt and Gm vary for different W*L. you can refer to the data and include the worst case variation in your simualtion.
But I am wondering the result will almost the same to keep one fast and the other slow, because fast/slow corner is design to represent the process variation.
So the safest way is to have W*L enough if you care about Ids variation.
you need focus on layout
To get the best result:
1: Use large area devices. For example dont use a 1um x 0.18um instead use a 10um x 1.8um. The larger the area the better they will match.
2: Make sure to scale W & L so the are deeply in saturation. This typically means that W should not be too large relative to L and that the Vgs overdrive should be large.
3: Best matching for devices placed next to each other with dummy devices on outside edges. Better matching will result if you interdigitate multifinger devices.
