how to use write_sdf command ?
quan228228
Full Member level 4
Full Member level 4
write_sdf
hi,
When i sythesis a design and then do a simulation. I found some warning in log when simulating.
Whe warning is like below:
Warning: Timing violation:.................
There are thounds of the warning. Why ? Did i use the comand "write_sdf" wrong in synthesis scripts?
In the scripts"
write_sdf -force_caculation -edges noedge -interconn none -nonegchecks -version2.1 /netlists/ cm3206.vg"
Help me?
/David
sdf generic write_sdf
i think many reasons: 1. you constrain mismatch your simulation invironment . 2. two clock domain
Added after 1 seconds:
    quan228228
write sdf triplet
check whether RST/PRESET etc are asserted /deasserted with proper timing. suggest to assert them on the unused edge of the clock
