How to creat a random data in verilog!
test_out
Full Member level 1
I wouldlike to check my design, and I want to creat a random data stream 36 bit. How can I do?
insert
$random
in your testbench
    test_out
hi,
The system task, $random, it can generates random number. It is a good practice to use it in the testbench to detect any hidden bugs in the design.
Ex.
// ur testbench
always @(posedge clock)
addr = $random(r_seed);
// r_seed is optional and is used to ensure the same random number sequence each time the test is run.
For more info, please refer to this book:
Verilog® HDL: A Guide to Digital Design and Synthesis
by Samir Palnitkar.
I think u can download this book from Edaboard.
Enjoy..
-no_mad
    test_out
$random, the verilog LRM or IEEE standard should be the best reference
i'm not sure how u can generate a 36-bit random value. $random provides only 32 bit max value. what you could probably do is, concatenate it with a 4-bit counter
to sree205,
you can use two random and combine them!!
    test_out
Hi, jjww110
Can you explain more detail, how can I combine two random to form 36_bit random value?
Added after 19 minutes:
ah, I got it, thanks you!!
use $random%(see_d) function
it will generate values betwwen -(see_d-1) to +(see_d -1)
To constraint to +ve values only
use {$random}%(see_d) so the values generated will be in the range 0 to (se_d -1)
