TV remote to controll ceiling Fan
makri
Full Member level 2
Full Member level 2
India, Kerala
bootstrap code download pic12f629
hello
anybody can help me to find a schematic for controlling ceiling fan with a TV remote control
makri
Take a look at the picture below ..
It shows IR receiver based on the PICAXE-08 microcontroller ..
Using standard TV remote controller with 38kHz IR transmitter and SONY-like set of commands you will be able to set/reset digital outputs ..
Bear in mind, that the PICAXE-08 microcontroller is a PIC12F629 pre-programmed
with the PICAXE bootstrap code, so you cannot use a ‘blank’ PIC12F629 with the
PICAXE-08 programming system ..
For more information go to: https://www.rev-ed.co.uk/docs/picaxe_manual2.pdf
and find the INFRAIN .. INFRAOUT commands ..
Regards,
IanP
