eejli
My LC VCO is working at about 2GHz. Phase noise between 100khz to 1MHz offset has a -26dB slope. Even after 1MHz offset the slope is still bigger than 20dB/dec. Phase noise at 1MHz offset is -116dBc/Hz.
How to improve the flicker noise upconversion? It seems the flicker noise upconversion is the dominant phase noise source since most of the phase noise specs is defined below 1MHz offset say 100khz, 600khz and 1MHz.
Thanks.
Thanks.
