ProPicXP problem with reading from flash memory
nesus
Newbie level 3
Newbie level 3
ProPicXP question
i am beginner in the microcontrloer proramming. i have bought a programmer which can work with ProPic XP.
so the problem begins with my attempt to write in the flash and eeprom memory of PIC16F84. there was no problem to write in the eeprom but when worte smething in the flash the propic did it but when i try to read it there was nothing in the flash memory
can you help me?
Re: ProPicXP question
Hi, try to program with the last old version of propic2.
Propic xp have some problem with 16f84
regard
P.S. the old version work with XP
Propic2 XP WRITE function been disable by author, unless you register and paid $.
You can use icprog or Winpic800 instead of Propic2 XP.
Use WinPic800.
the programmer i built for propic and it cant use any other program. i ve cracked the propic xp but i still cant write in the flash
any opinions?
ic-prog is direct support propic2 hardware, the function stable also indicate the IC position when select different device's.
You also can select the propic2 hardware at Winpic800.
But the program LED always "on" even after you have completed program and quite.
So call propic2 cracked (V21,97-18) is for old version only, you can change your name and appear it when access to the software, but useless....
    nesus
lmk thanks a lot
