What code should be used for 8 bit current mode DAC?
wany
About current mode DAC
i will do a 8bit curren mode DAC. what kind of code should i use. is it binary or thermometer. Thank you !
Re: About current mode DAC
It depends on your spec. The differences between two are mainly:
Binary code: Smaller area(no decoder and few switches), worse DNL, same INL.
Thermometer/Unit-element code: More area(needs decoder and much more switches), better DNL, same INL.
As a tradeoff, most people use a mixture of both. MSB bits are in thermometer code, LSB bits are in Binary code.
I read a very good paper about this topic before, it is a reference in Berkeley's EE247 ADC class. Highly recommend!!!
    wany
Binary
    wany
thank you jlee and omis .But omis why do you affirm to use binary? The sample rate of the DAC is 100MHz.
segmentation may be better.™
generally speaking, thermometer code is used when bit<=8bit while segmentation is used when bit >8bit
