Perfectly Matched Layers, first introduced by Berenger, are used to truncate the computational domains of several finite methods (like FDTD) in electromagnetics and fluid mechanics. The original PML of Berenger is
split field. Unsplit field PMLs are introduced by other researchers like Cangellaris, Petropoulos and others. I attach a MATLAB code of unsplit PML for the 2D FDTD method
There are many FDTD codes in C (including Berenger's PML) in the book of D. Sullivan
Electromagnetic Simulation Using the FDTD Method, Wiley-IEEE Press, 2000.
can you tell me where i can find it ?kprokopi
thank you !!
