How to convert 5V to 12V with 750mAh ?
nikhilele
Advanced Member level 3
Bangalore India
5v to 12v discrete
I have a battery backup system with 6V SLA(lead acid) battery,
But few ckts work on 12V which are used rarely. but they are important.
so how do i get it.
I know I need step-up DC-DC converter
I will be glad to know the chips and links to their datasheets.
Re: 5V to 12V with 750mAh
The power can be converted without inductors, see publication "DC/DC Conversion without Inductors"at:
However, the main drawback of this type of conversion is small output current, usually much below 200mA ..
Regards,
IanP
Thank you for your reply sir, this I have already gone through.
so our conclusion is we have to use inductor base step up convertor.
can any one suggest me more IC's
LM2577
LM2586
LM5000
MAX761
MAX762
and so on .. or, you can build dc-dc converter using discrete components:
http://www.aaroncake.net/circuits/6-12conv.htm
Regards,
IanP
    nikhilele
MAX608
MAX771
MAX772
MAX1771
these chips are costly and not easily available
So I finally selected MC34063
