VCO range 100KHz to 200KHz
ceaser
Full Member level 1
Egypt
vco 100khz
hi all
now i'm trying to desine a VCO has a range between 100KHz to 200KHz.
i tried to use the wien bridge osc.
but it gives me max freq of 20KHz because it use op-amp.
similarly 555 chip because it has two op-amp's in its two inputs.
i shouldn't use any freq dividers or multipliers.
just VCO sweeps from 100KHz to 200KHz.
can any one help me!
op amp vco 100khz
To design VCO operating in this range you can use part of the CD4046 ..
https://www.electronics-tutorials.com/devices/74hc4046.htm
A control voltage can be connected to pin 9, and output signal can be taken from pin 4 (see picture below) ..
The exact range and component values (R1, R2 and Cx) can be determined by extensive charts included in the above data sheet ..
Regards,
IanP
    ceaser
chemelec cd4046
thx alot IanP
Added after 4 hours 43 minutes:
Sorry guys
but now my instractor said
"no use of any chips you can use colbet or hartly tuned circuits "
but the problem of these circuits is the coil
we need coil of 70 mH
because the varying capasitors in the market are between 10&40 PF
so if there is no way to design this VCO without chips or op-amp's
i will make coil with large inductance
so any one know how to calculate the inductance using iron core
what i know is the inductance is a function of
No of turns,wire length,............etc
Use the AL value (from powdered iron core data sheet) and the formula(s) below to calculate the number of turns for a specific inductance.
Where:
N = Number of turns, L= inductance (µh), AL = inductance index ((µh) / 100 turns)
https://www.bytemark.com/products/ipcores.htm
Regards,
IanP
    ceaser
    ceaser
why don't you try:
rgds,
M
    ceaser
