manissri
Full Member level 5
hi all
why telescopin opamp has the input common mode level and out put common mode level is not same.
suppose the supply range is 0- 5 volts then the input common mode can not be 2.5v. and the output common mode level is at 2.5v.
where as in folded cascode the input common mode level and output common mode level can be at 2.5 volt for both input and output.
plz explain.
regrds
manish
plz explain.
regrds
manish
