Anachip
slew rate rise time
Hi Guys,
I'm confused on the mentioned parameters when designing an opamp. Can you explain me on my confusion?
1) What is the relation between 3 of them.
2) Why it is important to know the opamp settling time. Is that opamp settling time need to be faster than the rise/fall time of opamp?
3) Regarding, the slew rate, i know that is the rate at which output voltage change for a fiven max input (large current). So, what is the impotensy on knowing the parameters?
Pls guide me on all the above question so that i wil have some basic fundamental on opamp design.
Thanks,
Anachip
Hi Guys,
Thanks,
Anachip
