Problem with resistor divider output
vbhupendra
Full Member level 4
Full Member level 4
GOA, INDIA
pls see the resistor n/w
5V
R1
Vi-------R2------------Vout
R3
-2.5V
I want
Vout = 0V if Vi=-40V
Vout = 5V if Vi=0V
what resistor values should i use ? i tried many combination after solving the network but maximum Vout i could get is 4.44V only.
If you can solve it for at least 4.9V output i would be delighted.
Re: resistor divider output
The voltage on Vi & Vout should be the same because no current flow across R2??? Or include the termination of node Vout
i agree with paulux.
Your schematic not compeleted. we dont know current through R2!
and ask your question clear.
this post has ambiguity on it!
Hi. I thing your schematic is wrong, you must swap place on Vi and Vout.
Best Regards.
Pls upload ur complete schematic!
max current n/w can consume is 1.5mA
You can use superposition theorem and make 2 equation with
values of {Vout=4.95, Vi=0} and {Vout=0.2, Vi=-40}.
Then solve this 2 equation. result produce ralativity of resistor values.
Vout= 5*R2/(R1||R3) + (-2.5)*R3/(R1||R2) + Vin*R1/(R2||R3)
My gut feeling is that there is no solution for the values of Vin, Vout and Vref (+5 and -2.5V) you suggested ..
Drop the output voltage from 0-4.95 to, say, 0-4V, and use a rail-to-rail 5V opamp to extend the output range from 0-4V to 0-5V ..
Regards,
IanP
vbhupendra,
As petarpav suggested, Vi and Vout are interchanged. However the required voltage values given in the downloaded schematic are slightly different from the voltage values that you posted. Which ones do you want:0, 5 or 0.02, 4.95?
Regards,
Kral
Kral,
I want o/p to be 0.02V to 4.95V.
and Davood i solved it with different methods applying KCL KVL superposition etc. but the max i could get is 4.44V only. If there any solution to it contraint is i can use Vref as 5V and -2.5V only. or insert some coponents at the input side.
vbhupendra, IanP is right,
if VRef=+5V and Vr=-2.5V, then the required circuit in "resnw.pdf" for the stated i/o conditions a), b), cannot be realized:
a) Vout1 = 4.95V if Vin1 = 0V
b) Vout2 = 0.02V if Vin2 = -40V
because (Kirchhoff's Current Law):
(1) \[\frac{VRef-Vout1}{R2} + \frac{Vin1-Vout1}{R1} + \frac{Vr-Vout1}{R3} = 0\]
(2) \[\frac{VRef-Vout2}{R2} + \frac{Vin2-Vout2}{R1} + \frac{Vr-Vout2}{R3} = 0\]
Solving the above equations the following ratios for R1, R2 and R3 can be derived:
\[\frac{R3}{R1} = \frac{(VRef-Vr)(Vout1-Vout2)}{VRef(Vout2-Vout1+Vin1-Vin2)+Vout1Vin2-Vout2Vin1}\]
\[\frac{R2}{R1} = \frac{(VRef-Vr)(Vout1-Vout2)}{Vr(Vout1-Vout2+Vin2-Vin1)+Vout2Vin1-Vout1Vin2}\]
substituting Vin1, Vin2, Vout1 and Vout2 from a), b) we obtain:
\[\frac{R3}{R1} = \frac{4.93(VRef-Vr)}{35.07VRef-198}\]
\[\frac{R2}{R1} = \frac{4.93(VRef-Vr)}{-35.07Vr+198}\]
both these ratios must be positive! for the circuit to be realizable, so that
if VRef > Vr (numerator > 0), denominators must also be positive:
VRef > \[\frac{198}{35.07}\] = 5.64585...[V]
Vr < \[\frac{198}{35.07}\] = 5.64585...[V]
(or the second solution: VRef and Vr can change places ;-))
Conclusion:
For instance, if VRef=+5V, then Vr can be, say, +6V (min.~5.7V) or conversely (see an example in the enclosure).
These voltages have to be chosen first and then the above ratios can be calculated and finally resistors R1, R2, R3 chosen (so that the mentioned max. consumption is reached).
Best Regards,
Eric
    vbhupendra
This is one solution for your specific problem:
VoH = 4.95 = 5-(R2*7.5)/(R2+R3)
VoL = 0.02 = 5-((R2*(2.5+0.02))/R3) - 40/R3
R1 = 39.4K
R2 = 5K
R3 = 745K
R1 = 39.4K
R2 = 5K
R3 = 745K
Davood Amerion,
your circuit works, of course, but I can't find the reason for Vr (=-2.5V) in the end (I'm not reproving you for it ;-)).
R3 could also be grounded (different value then), it serves just to decrease VoH from 5V to 4.95V when Q1 is turned off.
btw. there's something wrong in your expression for VoL, the last section. Haven't you forgotten anything? The "-40/R3" implies to be a current...
In my opinion it should have been:
\[-\frac{R2(40-Vbe)}{R1} \frac{\beta}{\beta +1}\]
am I right?
Regards,
Eric
yes i mistak
Vol = 0.02 = 5-((R2*(2.5+0.02))/R3) - (R2)*40/R1
as i said it is solution for specific problem of vbhupendra.
dawood
i dont ve enough space to put anything.
vbhupendra
this was your sentence:
isnt it? :?:
dawood
yes i did said but now i realized hardly i could keep any component. thanks 4 ur solutions. thanks eric.
