How can I add non-plated holes in PowerPCB
antenna_abc
Member level 3
Member level 3
Hi, I have a question about adding non-plated holes in PowerPCB for assemble. How can I do it in PowerPCB? Thanks.
I would just build them as a part (component). Put them in your lib, and they will always be ready for other projects.
if u want to add a hole u have to first create it in the library and than use it
while creating u can edit it by right click-->query/modify->padstack
and u can tick mark or remove for plated and non plated below the drill size
Try adding the hole as a pad, in the padstack for the pad set all layers to be the same size as the hole or smaller.
Next select the hole type as non plated.
Then add the pad to wherever you want it on the PCB and fix or lock it so that it does not get moved by accident.
When you generate your NC-drill files you can have 2 files, file 1 has the plated holes only and file 2 has the non-plated holes only. This will ensure tat your board fab will give non-plated holes where you need them.
Phil.
HI,
You can create it as a component,in the padstack and save it as non-plated as told by v_kumar.
But then,when you need to connect it to the chassis ground then you need to provide a pad bit more then the drill size and can be connected manually.
Best Regards
RAME
Hole plating is done with chemicals.
To have some holes not plated you will have to get the manufacturer to cover the holes when plateing or to drill more holes after plating the board. They will charge you more money because they have to do more work.
