cmos babe
Full Member level 4
![Full Member level 4](/styles/images/ranks/flevel1.gif)
xilinx multicycle multiplier
Can someone show me an example of how this constraint is used?
According to the constraints guide :
When should this constraint be used? For example in my design the ALU is by far the worst-case path , how can multicycle path constraint be used in this situation ? and how will it affect the overall behavior of the design? THANKS
Multicycle Paths (FROM/THRU/TO)
Definition
Establishes a maximum acceptable time delay between groups of elements relative to
another timing specification.
