Current Mode Control of a Boost converter
mengghee
Full Member level 3
Full Member level 3
United Kingdom
boost converter current mode
Can anyone suggest simple and good readings for current mode control in a boost converter ? thank you
average current mode control of boost converter
Thank you very much. I have gone through the sheets but i am unable to find anything that is related to current mode control. can i have the url for TI website ? thank you.
Pls read this datasheet at first. From it, maybe u know a little regarding current mode control!
    mengghee
current mode boost converter ti
you could refer to the book 'fundamentals of power electronics', where the author introduce the CM converter in one chapter:)
    mengghee
Is the book 'fundamentals of power electronics' available for download here?
i don't have enough points..... do you know anywhere else i can get the book ? thank you
