flamingo
Member level 4
To get the performance of IM3 while keeping the output of amplifier 1Vpp, I used two methods: one is PSS single point analysis, using two tone signal with same amplitude which keeps output 1Vpp, the other is using FFT analysis in Hspice with the same stimuli. But the results from two simulators are so different. IM3 from PSS is much much better than the counterpart in Hspice, about 20dB higher. So which result shoud I believe??
And the fft results are inconstant with different simulation configurations, i.e., for different duration or step in .tran analysis, and different NP in .fft, get different results, variation is about 3~6dB, but they are yet incomparable to the result in PSS. what is reason??
