Help me select an RF amplifier
Grig
Full Member level 4
Full Member level 4
Hi
if I need ~10 MHz up to 1GHz small signal amplifier
50Ohm matching, gain ~15dB.... what's chiper solution?
Re: Help on RF Amplifier
MAR-1 from Minicircuits is a cheap solution:
    Grig
I had summit a pdf book "Advanced.Techniques.in.RF.Power.Amplifier.Design"
Best Regards,
    Grig
any MW bipolar transistor from Infineon, Phillips or Renesas with feedback wil be good for really cheapest solution (~35c BOM)
and Amps from Infineon and Phillips you can get for about 50-60 cents.
    Grig
use MMIC they have wide band and input z = output z = 50Ω you can cascade
them
:D
    Grig
