Fan control using a FET, ideal freq?
Jos Brink
Member level 3
Member level 3
I want to contol a Fan (24V/5W) using a Fet. I'm generating pwm with a controller (5V).
can anyone tell me:
what is the ideal pwm freq for this
and do you now a fet for this kind of application?
Thnx alot!
I don't think there is an ideal frequency for pwm controlled fans ..
I would start with quite low, say below 50Hz, but if you hear any noise you should try different one ..
I assume that you are after N-channel mosfet, so the popular IRF540 (or similar) will be a good choice ..
Here is an example: **broken link removed**
Regards,
IanP
mm and do you know a fet which is capable of driving this load with only 5V as Vgs?
my fet is cookin at the moment! :D (atm i'm using a FQD2N50)
but the frecuency is much better now, (running @ 100Hz)..
This mosfet is completely unsuitable for driving a low-voltage fan ..
Look at its parameters:
Rds(on)=5.3Ω
Vds=500V
Vgs .. ( https://www.fairchildsemi.com/ds/FQ/FQD2N50.pdf )
To drive a fan at 24Vdc you should select a mosfet with Rds(on)<0.1Ω
That was the reason I suggested the IRF540 with Vgs>2V, but any low-ohm low-voltage MOSFET will be good for this job ..
Regards,
IanP
    Jos Brink
I recomend to use single chip switching power supply.
for example you can use LM2576-adj and put potentiometer to feedbak path. In this way you can change output voltage from 1.2 - 24 volts.
Davood Amerion
but how would you like to control that with a uC? with a digital potentiometer?
Thnx for your tip, I already finished my design
so topic may be closed.
