mgf
Greetings ,
Need some advice on multiplexing high voltages in the range of 2KV to 12KV ( with a small current like 10mA to 80mA).
What I mean : is there any electronic component capable of that (i.e. thyristors, transistors, special IC, etc) switching in the High Voltage side, without using any transformers.
Multiplex stepping will be quite fast.
mgf
mgf
