hello joe2moon, the soc encounter doesn't recongnize the set_dont_use command.joe2moon said:>> ...insert buffer to fix timing.
Just write a SDC file, such as set_dont_use_cells.sdc, then use
"loadTimingCon"command to load the constraint.
encounter> loadTimingCon -incr set_dont_use_cells.sdc
Example of "set_dont_use_cells.sdc"
set_dont_use your_lib/buf16
set_dont_use your_lib/buf20
sam31 said:Hi,
Why you don't want to use buf8 ,buf12 and so on ?
