advaitha
I am trying to simulate a large (>100K elements) post-layout parasitc netlist. The only tool available to me is Cadence Spectre. The system being used has 8GB RAM and runs on 2 Xeon processors at 2.7GHz each. The OS is Redhat Linux 8.0. The System monitor shows that the Spectre process uses only upto a little more than 3GB of RAM and then returns the error 'Insufficient memory'.
Can anyone suggest a method to eliminate this error and finish the simulation?
