mediative
When I do timing analyzing by SOC Encounter, the terminal prompt me : Timing graph must be built before running "reportSlacks"
and erenow when I build time graphy, the terminal give me the following warning:
Reading timing constraint file '../design/top.sdc' ...
**WARN[line 20]: Skipped invalid point odsp_mode
**WARN[line 21]: Skipped invalid point odsp_mode
**WARN[line 215]: Skipped invalid point odsp_mode
**WARN[line 215]: Empty -from list associated with set_false_path statement
**WARN[line 217]: Skipped invalid point core/oe_pad
*info: set_clock_latency : 2 accepted, 0 skipped!
*info: create_clock : 2 accepted, 0 skipped!
*Info: refer to log file for more detail on skipped constraints if any
*** Mark 1491 set_logic ignored terminals ***
*** Read timing constraint file (0:00:00.0) ***
*** Constant propagation (69 ignored terminals) (cpu=0:00:00.0 mem=192.8M) ***
*** Mark 15295 ignored terminals (0:00:00.2) ***
*** Initialize timing graph (0 nodes, 0 edges) (cpu=0:00:00.0 mem=192.8M) ***
**WARN: Empty timing graph!!!
any point of view is thankful !
