[HELP]Who have known about this error?
flyankh
Member level 5
Member level 5
port type table is not defined
Hi
I stream in a gds file into milkyway lib,and when I do BPV ,I get the error as "ERROR : port type table is not defined",have anybody seen it ?And how to solve this problem?
Thanks in advance!
Flyankh
hi,
You need create a file and load in Astro window as following list:
dbSetCellPortTypes libName cellName portList append
Best Regards,
Jeffy
    flyankh
yes chyau is right
you should to load the prot defined file in Milkyway or Astro
you can reference Astro mannual
