Pushhead
Full Member level 4
cst network parameter extraction antenna
Hello all,
I'm simulating a periodic 2D planar structure. I am using a plane wave excitation to achieve the phase of the reflection coefficient.
As you'll see in the following pictures, I have used only one cell of the structure with periodic bundary conditions (sidewalls), Electric (bottom) and Open (initial wave-plane position). In addition i'm using several field-probes above the cell.
My main problem now is an unexplanable phase result (see picture). I get weird "jumps" of phase values. I understand that the angle is wrapped between -180 and 180 - but I cant explain that!
Why is this happening?
Do you have another idea of retrieving the phase of the ref. coeff. ?
Looking 4ward 2 your ideas and thoughts,
Tnx alot,
P.
Hello all,
Tnx alot,
P.
