Chips in LCD module ODM 16216
sandeepa
Newbie level 3
Newbie level 3
Hello
Has anyone used the LCD module ODM 12216 from Oriole?What chipset is it based on?I cant find its manual giving timing details and commands anywhere.
This is the only information on the companys website regarding this module.
There are 2 chips on the back and one of them has
SEC c8048
KS0066F00.
Any idea what these numbers mean?Googling for these doesnt come up with anything useful.
Thanks.
oriole,lcd data sheet
The KS0066 / KS0066U is software compatible to the industry standard HD44780 controller. So you have a very standard LC module.
The only thing that is a little bit different is the fact that the backlight uses only one pin (hence 15 pins, instead of the more common 16). But that should not cause any trouble.
General character LC module info:
KS0066U controller datasheet:
http://www.hantronix.com/down/ks0066u.pdf
    sandeepa
