triquent said:When I let vdd rise from 0V to 2.5V, I got a ripple or spike output about 530mV(stable Vref=1.26V, the spike is 1.79V ). Seems the ripple is too big. How can I reduce the ripple or spike? How to change or compensate the circuit?
hspice2008 said:I use pwl source ,let vdd rise from 0v to 3v in several ns . then I can see whether the bandgap output can reach its final value without ripple, if have ripple, I will change or compensate the circuits, to eliminate it
in addition , I will run all conners to test the startup of it
Added after 13 minutes:
when we simulate the bandgap voltage reference, usually we put a capacitance at the output(Vref). Does this capacitance represent the parasitic capacitance? So it is put there just for simulation purpose and for real case? Or it will be implemented by layout?
