layaghi
Member level 3
ethernet controller microcontroller
Hi to all
I need to build a Hardware which could receive 1 MByte/s from a ethernet line and then process it. I want to select a suitable microcontroller with built in ethernrt controller.
Searching products of Maxim,Motorola, Atmel, ... I have found several devices. Now I want to select one of them and begin my design. The important parameters are:
speed: Fast ethernet (100 Base)
ease of use: simple programmer, availabe libraries,...
ease of PCB design: 2-layer, and not to require special requirments in PCB design
and cost.
If you are experienced with such products please give me your guidelines to choose the best product.
thanks.
Hi to all
and cost.
thanks.
