Difference of size and length in Matlab
Antonio_Magma
Full Member level 2
Full Member level 2
What is the difference between size and length in Matlab? I've checked the help but i dont understand..
Size returns the dimensions. Length returns the largest dimension. This is what I understand from the HELP documentation. Seems quite clear.
Yes this i understand. But size returns dimensions...what dimensions?
Does it mean if i am using a vector i should use size and when using arrays i should use length?
