Control the dimming of lights using microcontroller
glenncjy
Newbie level 6
Newbie level 6
microcontroller dimmer
hi guys,
Im planning to do a project whereby i need to control the dimming of lights.
Rather than limiting the current by manually design the ckt setup, is there any commercially available microprocessor whereby i can do the a/m process.
If yes, may i know the brand and name of the processor.
thanks alot
igbt light dimming
glenncjy said:
hi guys,
thanks alot
here you go
lighting control system using microcontroller
I see one application note from Zilog explaining how build one dimmer for resistive load.
For more details, visit zilog home page.
Gorkin.
dimmer microcontroller
hai
Thanks fragrence for the attachement.
I have some clarifcations required .
How can I debugg the system using ICD because I have some altrations to suit my purpose .
The system is live so cannot connect the ICD or any other things.
But we can drive the picmicro from a DC sourse during development,But how then we can we give the input to PORTA for zero crossing detection?
can you suggest the best method to isolate the device from AC at the same time give input to I/O of pic to get the zero crossing?
If I use a optocoupler triac driver(MOC3021) for driving triac can we drive the triac from PWM output of PIC16F628 with 10ms period?
Please suggest. I am in A very urgent situation regarding this project
Picstudent
triac dimmer microcontroller
you can't use pwm with triac !
a triac cannot be turn off until next zero crossing
you must use igbt with pwm
light dimmer using 8051
Picstudent said:
hai
Picstudent
yes you can used triac with optocoupler moc3021 in pwm never used moc3041 or moc3040 i have temperatuer controller using pwm with moc3021 and driving triac
regards
Fragrance
microcontroller light dimmer triac
[quote="Fragrance ] yes you can used triac with optocoupler moc3021 in pwm never used moc3041 or moc3040 i have temperatuer controller using pwm with moc3021 and driving triac
regards
Fragrance[/quote]
can you give some more details about period of PWM and how or weather you synchronise with AC ? My purpose to control the speed of a ceiling fan
Picstudent
phase control using microcontroller
Controlling AC power with a triac is called phase control. If you intend to control power delivered to the lamp wit a triac, you should trigger the triac at a certain point in the AC cycle that gives you the required RMS voltage output. PWM can be used if you intend to supply the lamp from a DC source. I did it before with the PIC16F876 PWM and a power transistor and it was excellent.
micro controller phase control
Check for pic reference on chip 12c508,Bst application on dimmer.
microcontroller light dimmer control
What you have to do is:
- Circuit for AC zero-crossing optoisolator detection.
- Circuit to delay amount for time since zero-crossing occurs, which then enables an output to occur until the next zero-crossing.
- You have to convert the amount of time delay against a light-curve look-up table, because light brightness doesn't change in a linear line, which is done with a microcontroller.
- The output from the timer circuit drives an optoisolator which trigger a triac circuit or a AC power switch "brick".
- You will need a big inductor in the AC output to reduce switch noise, otherwise will cause lots of RF interference.
Added after 12 minutes:
Here is a circuit that I found on the internet, some great ideas.
  • ac_light_chaser_circuit_1233.pdf
microcontroller dimmer edaboard
Hai Enlightenment
Thanks for that circuit
Where can I find the code for that?
Can you help me
Nandhu
moc3021 pic
glenncjy said:
hi guys,
thanks alot
YOU can use a z8 microcontroller and use a Pulse with modulation to control the brightness of a bulb.
microcontroller light dimmer controller
well i have one as well, this one can conrol single phase motors as well, using PIC16F628A,
here, portb is the speed configuration of the circuit. i hav put 2 dip sw's, 0 being off state and 255 is full/on state. u can put a 8 bit counter / modify the code / add a 8 bit port of a mcu with up/dwn buttons
for any help plz let me know
regards
igbt light dimmer
IGBT is good on performance and easy to control, price is high.
Triac is cheap but need AC zero-crossing optoisolator detection and exteral control.
Light dimming is a wide topic.
pic pwm zero crossing detector light dimmer
How much is the chip now?
fan dimmer using 8051
We are call this method " Phase controller ", by you must have a reference signal from AC source 50Hz or 60Hz, the connect this signal to your microcontroller external interrupt pin for reference to make the phase control signal. Using the timer to on and off the control signal.
microcontroller ac light dimmer
what should be change if 60hz 220v mains is used?
thanks
