trace width consideration wrt current
tramp
Member level 5
Member level 5
india
Hi ,
Is there ratio between track width wrt current flowing?
I assume you are talking whether there is relation between trace widths and the current flowing in it. Yes there is, as for me, the greater the amount of current in a net, the wider the trace should be, and if current is smaller, you can make the trace width thinner.
Better check this site, this is a trace width calculator:
http://www.geocities.com/CapeCanaveral/Lab/9643/TraceWidth.htm
    tramp
hi,
In that calculator what is Conductor thickness [oz. per sq. ft]?Is it cupper thickness
which 50microns in my PCB?
Enter Conductor Thickness: [oz. per sq. ft.]
1 ounce per (sq. foot) = 0.305151727 kg / m2
Typical copper thicknesses are:
0.5oz (17.5µm), 1oz (35µm), 2oz (70µm), 3oz (105µm)
Regards,
IanP
    tramp
