circuit
Full Member level 2
xilinx mcs
Hi, I am a newbie to FPGA programming. I have a board from analog devices containing xilinx virtex II fpga chip and Xilinx XCF02S PROM. they also gave me the verilog code/.bit/.mcs files. I just want to try to load the mcs file to the chip for starters because i will be later working on modifying them.
I have xilinx ise webpack and i generated the bit file and the mcs file.
I did all this appropriate to my project,
Generate PROM, ACE ... File > PROM File > xilinx Serial PROM > File Format MCS and Fill FF > PROM name ie ADI.mcs and PROM Location - C:\ADI\FPGA
> PROM type: xcf02s > Add File and Selected the bit file > another design NO
> Finish
Now to download the program to the device, what configuration mode do i use Slave Serial ? . I was told to use the mcs and bit file in series and right click on the mcs file to get the program menu. But I find in serial mode I can add only one xilixn device ? Please let me know how i can do this....I am using parallel cable IV. thanks !
Back to top
> Finish
Back to top
