Need a good video filter for baseband PAL video with delay compensation
DrWhoF
Advanced Member level 1
I need simple but good video filter for baseband PAL video but with Delay Compensation.
Schematic will be appreciated.
Thanks.
DrWhoF
Re: Video filter
Passive or active?
I think active filters are better option ..
Attached is the schematic of 5-pole baseband video filter with group delay equalization ..
Regards,
IanP
    DrWhoF
Re: Video filter
These opamps are pretty expencive.
What about a passive video filter?
Thanks.
DrWhoF
Re: Video filter
This passive filter has no group delay compensation, but if you would like to have this compensation you can replace the last 3-transistor amplifier with a buffer (same as the first stage) and add the group delay compensation identical to the one from the active filter option ..
Regards,
IanP
    DrWhoF
