Looking for software to test C coding output before burning it on microcontroller
hameeds01
Advanced Member level 2
Islamabad Pakistan
I m looking for such a software in which i can write the C coding & it shows the Output without burning it on the MC
I want to test the output before writing it on the mc
Re: help help !
It's called an emulator, and it should be specific to the microprocessor that you are developing.
    hameeds01
Re: help help !
Right now i m using AT89C51
Send me the link from where I can download “ free “
Re: help help !
If you want to execute the program in the hardware you need an emulator and the hardware. Code will be residing the emulation controoler RAM.
Simplest is to use simulators, there are many simulators available on net. The best one being from KEIL. You can download evaluation version of KEIL compiler / debugger/simulator from www.keil.com
Cheers
Re: help help !
in proteus tool u can draw the schematic of ur circuit and then attache ur code to
the ucontroller u use
(which is called hw/sw co-simulation)
if the out is ok u can burn the controller using the suitable programmer.
