best graphic LCD controller ???
ambition
Junior Member level 2
best lcd controller
hi
I have a question regarding interfacing graphic LCD ,and I would be thankful if someone could answer me :)
what is better for graphic LCD ....
should I use basic microcontrollers like ( PIC or AVR ) ???
or I should use one of these popular controllers : Toshiba T6963 , SED1330 , Hitachi HD61202 ??
mentioning that the graphic LCD controller will be connected to another microcontroller ( not a computer !) .
Moreover, I searched a lot for a step-by-step tutorial for graphic LCD , but I couldn't find. All what I find is character LCDs tutorial and I wonder if they are similar to program or not !
please help :cry:
graphic lcd controller
hi:
i think that u have to try BASCOM AVR . it support all graphic lcd
regards
    ambition
what is the best lcd controller
this should help you out
    ambition
graphic controller
i have used graphic LCD with controller T6963. I have interfaced it with 89c51. i used t6963's manual to learn Graphic LCD.
try n read that manual. its very easy to use n very interesting too.there is no step by step manual for this. u have to follow t6963's manual.
best of luck
graphic lcd character
matelda
thanks ^_^
bbarney
how can I thank you ???
this is really what I was looking for..
thanks a lot
misha82
Thanks . Fo now , i have no problem in interfacing the lcd to the controller ...
using T6963 looks easy
but I wonder how can i interface this T6963 to a PIC
In fact, I'm a beginner in microcontrollers and I don't know if I would face a difficulity going this way ?
can anyone help ??:)
graphic lcd control
U can ctrl the T6963 thru parallel bus.
lcd controller tutorial
hi:
welcome friends
in fact i neet pic compiler that support all lcd graphics
regards
hd61202 pic
huozee
I mean that the T6963 will be connected directly to PIC and that will be PIC 16F877
give me a minute to explain the idea :)
the PICF877 will act as the (head) controller that
controllers different devices through thier controllers
so the PICf877 will controller that T6963
could that be done ?? or I'm just imagining :s?
matelda
I hope someone can help
lzgq771001
this site looks great but unfortunately it's not in English :( thanks
explain it what is mean the lcd controller
A example of T6943.
glcd bascom tutorial
Hi
I used also T6963 to control LCD
