winsonpku
now,i am designing a S/H circuit,which is used in the 14-bit pipeline ADC.then i want to know if the S/H circuit's resoluation is about 0.03mv,does it mean that:all the parameters in the circuit is at the accuracy level.for example,the AMP's output CM voltage,the sampling,the swtich's charge injection or clock feedthrough must be at the accuracy level.
another question is how to test the S/H circuit's resolution,i mean when i simuate the circuit by Hspice and how i debug the circuit when the accuarcy is lower than the specification.
any advice is welcom! thanks
