Re: How to add the S-parameter into @DS(2003A) Library?
I did it as following:
enter"system-passive"----->select"two port"component------>double clickthe component------->instance name enter:bfp620f---->parameter entry mode select:file based----->data access component instance:E:\(that my s2p file entry)------>dependent parameter name entered:bfp620f or bfp620f.s2p------->apply.
But in Vain(indicated"syntax error in value",i do not know what happens.I changed another corect s2p file that can be used successfully in EEsof,the same problem.Can you tell me what is the matter?
thank you a lot!
