cyberblak
Full Member level 2
high voltage measurement
Hi all,
I got a system in which I need to measure a highly noisy 48V signal (this is the output voltage of a switching power supply). Since it's a noisy environment, I thought of using a difference amplifier. My question if how do I need to scale down the signal to 2.5V without affecting the measure quality? If I use a voltage divider circuit and then enter this signal in the diff. amp, the linearity will be affected, isn't it? Is there a way to scale it down while still keeping a high CMRR and linearity?
Thanks,
CyBeRbLaK
Hi all,
Thanks,
CyBeRbLaK
