Suggest me a GPRS module to use with PIC
BasePointer
Full Member level 2
Full Member level 2
TURKEY
Hello Friends,
I'm looking for low cost GPRS Module to connect my server (listening tcp port 2256) written in Delphi over internet with PIC18LF4620.
- What kind of module do I need for this (or be enough)?
- What should I know at PIC side as software? I'm using hitech C and I can easily send and receive any data over its UART.
- Which gprs module do you advice me to start my project, it should be stabile and cheap.
- Where can I buy a module immediately?
10x
gprs pic
Try TELIT GM862 PCS
    BasePointer
at+cipstart
shashavali_m said:
Try TELIT GM862 PCS
10x shashavali_m for orientating.
Have you used this module before?
Will I need any software stacks implementation with this?
Is it working stable ?
What is the difference between GM862-PCS and GM862-GPRS?
What is E-GSM 900/1800 MHz and E-GSM 900/1800/1900 MHz?
gm862 pic
What about SIM100S32-E?
It's only 35$ and has embedded TCP/IP stack.
Anyone used it before?
Is It wotking stable ?
pic com gprs
is there a link to choose from?how can we check the useability?any info..?
    BasePointer
pic+gprs
gorkin said:
Hi guys!
For get more information about SINCOM modules, try these link:
h**p://www.simcommunication.com/english/productssolutions/wirelessmodule/sim100s.htm
Gorkin.
They have written SIM100S had "An embedded powerful TCP/IP protocol stack"
But someone said It isn't so. Anyone test it? Do we need software implementation for PPP and TCP/IP stack?
gprs com pic
Yes, SIM100S32E has got a TCP/IP stack. Also one dosent need to write a PPP stack. Iam using it it is working fine.
    BasePointer
gprs pic
For example, How can I send my nick name "BasePointer" as string to a server that listens TCP port numbered 2256 with SIM100S32E after all communications procedure? Can you show us that with one line AT command?
pic ppp stack
You can to probe with MC56, Siemens module
It had two way to access to internet:
1- Using functions or commands GPRS with a external stack TCP/IP
or
2- Using functions or commands to access to Internet with internal stack TCP/IP
Best Regards
    BasePointer
gprs module internet ip address
This cannot be done in a single AT command.
A series of steps have to be followed.
Step 1:AT+CGDCONT=1,"IP","<apn>"
<apn> - This is the apn given by your service provider
Step 2:AT+CSTT = "<apn>","<username>","<passwd>"
Step 3:AT+CIICR
Step 4:AT+CISFR
Step 5:AT+CIPSTART="TCP","<IP address of your server>","port No"
In your case port no will be 2256
Step 6: AT+CIPSEND=<data to send> CNTRLZ
In your case data to send will be BasePointer.
In the server there should be a server socket program listening in 2256 port .
    BasePointer
module gprs pic
Step 3:AT+CIICR
Step 4:AT+CISFR
It seems easy vdharan.
I decided to start with it.
10x for this.
simcomm
if somebody know which AT comands should be sent to Siemens TC65 to get the same result?
gprs with pic
Does the TC65 has a built in TCP/IP stack?
sincom modules
I can't seem to find a list of AT Commands for Nokia (6310i) for GPRS. Does anyone have them?
Best regards,
Trax
pic gprs control
Are teher any code like it Siemens MC35i? how can i sende Data throu GPRS ?
gprs+pic
I dont think you will get a readymade solution for MC35. What is your application
pic gprs modül
I am intersted to buy a SIM100S32-E where can I find it. I want to built a board with a GPS and a GPRS for vehicle tracking, has anyone did that before. At a god price
gm862 telit türkiye
There are many posts on this forum. Search
