What's the microcontroller and what's the microprocessor ?
cnchip
Newbie level 5
Newbie level 5
P.R.China
microcontroller compare microprocessor
What's their differentia ?
I'm sorry,I don't know!
thank you !
need for microprocessor
Micropocessors; need external preferals to work like
EEPROM for program to be runned, RAM to save data into it, external clock,
external I/O ports and of course collections of buffers, Bi-Directionals,
and decoders.
Microcontrollers; are integerated device contains CPU core, and EEPROM,
RAM, I/O ports, Internal Clock, of course it's functions are weak and slow
if compared with Microporocessors, but they wholy stand alone system
    cnchip
comparing microprocessor and microcontroller
Microprocessor is only the processor and no peripherals are integrated like
memort controller DMA etc.
but the are very high speed chips
where as the microcontroller are integrated with various devices like ADC DAC USB memmory etc the are not so high speed and since every thing is integrated it is easier to use and cost is very less compared to Processors
    cnchip
what’s a microcontroller?
thank you !
microprocessor (MPU): only the core processor with no peripherals.
microcontroller (MCU): core processor with lotsa peripherals.
    cnchip
microproccor
micrporocessors need external memory while controllers have there built in memories
    cnchip
wikipi microprocessor & microcontroller
a microcontroller is a true computer on a chip.
it has all the necessary memory, input output controllers,and verything else to make it ready for use.
a microproccor on the other hand is just the processing unit. it is realyy useless without the motherboard.
    cnchip
microcontroller vs microprocessor comparison
when comparison do on processor and microcontroller... processor always seems pitty,,,
IMHO
when it come to processing power... none microcontroller can compare wth it...
it easily outclass all the controller...
regards,
sp
    cnchip
The defference between them is becoming less and less with the electronic integration technology development.
    cnchip
Re: What's the microcontroller and what's the microprocessor
Not indeed.
Microprocessor is a microprocessor although is more powerful than microcontroller. Microcontroller indeed is a computer,loosely based, because has everything.
Take one example I/O ports. Computer has them. Microcontroller has them. Microprocessor does not have them. Difference between computer to a microcontroller is level of those I/O ports. There are more differences like power etc. like even ancient computers are faster then a microcontroller for example.
    cnchip
Added after 28 seconds:
microcontroller having inbuilt memory ,but microprocessor does not has inbuilt memory
    cnchip
how about the L1 and L2 cache?....
sp
    cnchip
Microcontrollers having builtin memory and general purpose IOs.(You can it switch as serial,parallel,special ,analog, pwm and other.
Microprocessor can you use only with outer pheripherial.
    cnchip
Microcontrollers are used in the field industry control or the embedded application, they have the IO device such as the timer/counter, UART, PWM, AD/DA, SPI, FastIrda etc.
Microprocessors are used in the field computer.
    cnchip
Microprocessor have DATA and ADDRESS bus. Microcontroller - have only IO ports instead.
    cnchip
Microcontroller is a system on a single chip, whereas the microprocessor is a chip in a computer system.
Microcontroller with its integrated pheripherals is a low cost chip and is mainly used in embedded systems, which require limited data processing .
Microprocessor is mainly used in general purpose PC's.
The main difference lies in processing speed and data handling capacity.
    cnchip
thank you thank you...
best wish to you
I have added 3 points for everone.
i think Microprocessor stable more than Microcontroller.
bubee
wat u mean by stable here.... did u read the reply post by others ?
eg 80186 is a microproessor mean while AM186 is a Mircocontroller which incorprates the 80186 microprocessor core + some more blocks
