Question on Arrays in Verilog
easytarget
I'm learning Verilog on my own right now and I'm stuck, please help. I'm confused how arrays are referenced. Here's the code that confuses me:
//first, the declarations, I have no problem with them:
input [width-1:0] data_in;
input clk, reset;
output [width-1:0] data_out;
reg [width-1:0] pipe [0:length-1];
wire [width-1:0] d_in [0:length-1];
//now here's what's confusing me:
assign d_in[0]=data_in;
assign data_out=pipe[width-1];
My question is how can you assign values to things with different dimensions? can someone tell me which elements are assigned wich values in the above code? This is from a book called A Starter's Guide to Verilog 2001, page 136. Thanks for your help.
pipe is a group of "length" registers. Each register has "width" bits. It's a (length x width) memory.
d_in is a group of "length" data busses. Each bus has "width" bits.
That copies data_in to the first data bus.
Oops! That looks like a mistake. It tries to use width-1 as an address into pipe.
    easytarget
You have specified two kinds of array, one-dimentional and two-dimentional.
The code "input [width-1:0] data_in;" specifies a one-dimentional array. It means data_in[width-1] til data_in[0] which indicates a signal by width bits.
The code "wire [width-1:0] d_in [0:length-1];" describes a two-dimentional array. This array includes "length" members that each of them indicates a signal by "width" bits.
assign d_in[0]=data_in; ----> data_in[width-1:0] is assigned to d_in[width-1:0][0]
assign data_out=pipe[width-1]; ----> pipe[width-1:0][width-1] is assigned to data_out[width-1:0]. It means (width-1)th element of pipe is assigned to data_out. In this case, "width" should be less than or equal "length".
rgds,
KH
    easytarget
