How to use mosis spice parameters of amis process in Cadence?
ramraj_gp
Newbie level 6
Newbie level 6
Can anybody tell me how to use mosis spice parameters of amis process(as listed **broken link removed**) in Cadence.
Re: Cadence simulation
You can just strip out the model statements into another file and include that file as a model library (i.e in the Analog Environment)
But those parameters are Hspice parameter. Are those parameters compatible with cadence or do i have to convert them to spectre format?
Cadence simulation
Check this out:
Edit:
An even better way would be to add the following on the first line of your hspice file:
simulator lang=spice
then change level=49 to level=11 for both nmos and pmos
    ramraj_gp
