what's the diff between Pre_layout and Post cell delay cal
bendrift
Member level 4
Member level 4
delay calculations
what's the diffirence between pre_layout and post_layout in cell delay calculation?
in the library , cell delay is affected by the input transition and output capacitance.
but during pre_layout ,the RC on the wire is not exact.is it will affect the gate delay calculation?
and many times , i saw the delay calculation refer to capacitance, but where the resistance reveal in library and in the cell delay calculation?
thank u :)
Re: what's the diff between Pre_layout and Post cell delay c
In general pre-layout use EWL(estimate wire load model) to calculate network delay.
Read the attached pdf.
I assure you this will remove all your doubts regarding the cell delay calculations and will further add to your knowledge.
do let me know if i am wrong in saying this.
regards
    bendrift
thank for ur help,nittinsharma80!
it's a very good paper for sta.
do u have deep material for postlayout sta?
for i am not familiar with SPEF and Arnoldi.
best regards
i suggest u use report_delay_calculation option in pt. This gives complete info on how it computes delays.
or one can use report_timing with justify option.
